fast-cgi
Huub
hfl at HOME.NL
Fri Apr 29 07:42:57 EDT 2005
Hi Ed,
I can't say that i have a clear understanding of how this works or what
can be expected. I suppose i read in the manual a little more.
As i understand it, connections to the database are cached. Does that
mean that the data are cached? That is a different sentence to me.
And in the setting we ask for -idle-timeout 300-killInterval 500, i
assume that a fcgi process is released after 5 idle minutes. But that
didn't happen.
Also i saw three fcgi processes and i was the only user (or does every
browser refresh make a new 'session'-process).
And, memoryconsumption increases continuously; in my first message i
said that the meter said 2.5Gb. The server i'm talking about in not
heavily used. I expect memory to be released once in a while.
So what would that bug be? I was inclined to formulate it like 'who
knows which bug to file and to whom'?
So thanks for your question.
Regards, Huub
Ed McNierney wrote:
>Huub -
>And what would that bug be? Caching is a good thing - since there are
>no other demands on memory, and fast-cgi processes are SUPPOSED to stay
>resident, how can you tell that anything's wrong?
>What would you EXPECT the memory usage to be? Since RAM is good for
>caching, it's usually GOOD for programs to use as much available RAM as
>they can take advantage of, as long as they're not competing with other
>applications.
> - Ed
>Ed McNierney
>President and Chief Mapmaker
>TopoZone.com / Maps a la carte, Inc.
>73 Princeton Street, Suite 305
>North Chelmsford, MA 01863
>Phone: +1 (978) 251-4242
>Fax: +1 (978) 251-1396
>ed at topozone.com
>-----Original Message-----
>From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
>On Behalf Of Huub
>Sent: Friday, April 29, 2005 6:26 AM
>To: MAPSERVER-DEV at LISTS.UMN.EDU
>Subject: [UMN_MAPSERVER-DEV] fast-cgi
>Hi List,
>(new thread,the same name)
>Well,
>this morning i could see that memoryusage was over 700Mb the 8
>mapserv.fcgi processes were gone.
>After stopping apache the memoryusage of the server dropped to 414Mb
>Then i continued to use (the improved)
>http://213.197.234.107/testfcgi.htm (now timing results)
>after lets say 50 zoomins/outs (50 for 4.5 cgi and 50 for 4.6beta fcgi)
>10.05h i see 3 mapserv.fcgi in the processlist memory is 873Mb 10.15h 3
>mapserv.fcgi (154672Kb,156128Lb,20000 Kb): 740Mb 10.45h 3 mapserv.fcgi
>(154672Kb,156128Lb,20000 Kb): 740Mb (now i closed the browser) 11.15h 3
>mapserv.fcgi (154672Kb,156128Lb,20000 Kb): 740Mb Stopped Apache.
>mapserv.fcgi gone, Memoryusage dropped to 414Mb
>am i missing something, or should i file a bug
>httpd.conf fastcgi settings
>LoadModule fastcgi_module modules/mod_fastcgi.dll AddHandler
>fastcgi-script fcg fcgi fpl FastCgiConfig -idle-timeout 300
>-killInterval 500 -initial-env PROJ_LIB -initial-env PATH -initial-env
>TNS_ADMIN SetEnv TNS_ADMIN
>"c:/oracle/product/10.1.0/Client_1/NETWORK/ADMIN"
>SetEnv PATH "C:/Oracle/product/10.1.0/Client_1/BIN"
>Regards, Huub
