Image Caching, when to update?
Steve Hall
steve.hall at MERCATORGEOSYSTEMS.CO.UK
Fri Aug 5 11:23:27 EDT 2005
FYI.....
I use the Oracle MapViewer product in quite a few projects which does have
some caching facilities which can lead to incredibly fast map production.
Each layer (theme) has 3 options - no caching, "normal" caching and "all"
caching.
No caching is pretty obvious and I guess (not knowing much about it) is
synonymous with how MapServer works now. This is intended for use on
dynamic data layers.
"Normal" caching will still execute the query against the database but any
returned rows that have previously been fetched will use a cached "decoded"
geometry object instead of having to decode the database geometry to create
the MapViewer internal geometry. The Oracle ROWID is used as a "key" to
identify previously fetched geometries (like the Postgres OID).
"All" caching will fetch the entire table out of the database the first time
it is requested (i.e - slow!) and from then on is used purely "in memory" so
no requests to the database are made at all. Obviously this can imply a lot
of RAM (a 1 or 2gb in-memory cache is usual, depending on layer size). If
your data is large, and static, then this can lead to fantastically fast
maps.
Additionally there is a request that can be made to the server to clear the
cache if required.
I guess Oracle has it's ROWID, PostgreSQL the OID - what about Shape and the
other formats? Do they all have suitable "keys" that could be used for
feature identification? The approach of caching geometry, as opposed to
images, means that individual requests don't need to be *identical* to take
advantage of the cache.
Hope this is of some use.... MapServer is a great product, my thanks to all
developers past and present!
Steve H
----- Original Message -----
To: <MAPSERVER-DEV at lists.umn.edu>
Sent: Friday, August 05, 2005 4:01 PM
Subject: Re: [UMN_MAPSERVER-DEV] Image Caching, when to update?
> Sean Gillies wrote:
> "IMO, MapServer should remain focussed on rendering map images, and
> caching
> should be left to other specialized applications or modules."
> If that's the case, that you don't want image caching built into
> mapserver,
> maybe we need a component in the overall system, between mapserver and the
> WMS interface to deal with the issues of caching geographical imagery.
> Even if you don't do image caching, I believe caching of some things
> internally would be beneficial in mapserver so it can run faster. If
> mapserver was fast enough, I wouldn't even have to worry about image
> caching.
> I'm just trying to brainstorm here where this image caching system should
> go
> and how it should work.
> -Kyle Mulka
> http://www.kylemulka.com
