MapScript Unit Tests (Re: OGR/WKT)
Sean Gillies
sgillies at FRII.COM
Wed Aug 10 17:25:18 EDT 2005
On Aug 9, 2005, at 2:29 PM, Steve Lime wrote:
> I probably should take you up on the offer (thanks), but then again I =
> should be=20
> doing that myself as well. Lemme try it myself with you and Sean as =
> sounding boards
> if that's ok. I gotta get the RFC up-to-date first anyway.
> Steve
Steve,
I just committed a new test case to
mapscript/python/tests/cases/shapetest.py as an example for new
shape/WKT tests. See the ShapeWKTTestCase class near the end of the
file.
If I were starting from scratch, I'd set up the unit testing framework
differently (and better). It's a bit obscure, but coming from a Perl
background should prepare you well ;) As it is, each file in
tests/cases ending in *test.py is a test module, with modules for each
of the mapscript classes. Any of these can be executed like
$ python shapetest.py
or
$ python shapetest.py -v
for more verbose output. The main() method of the module runs all the
test* members of every TestCase-derived class in the file. Adding a new
test is as simple as writing a new class, and is automatically added to
the test suite. There is a script called runalltests.py in tests/cases
that aggregates the tests in all modules, and can be run like
$ python runalltests.py -v
For my convenience I have made a shell script in my mapscript/python
directory which cd's to tests/cases, runs all the tests and returns to
mapscript/python. This allows me to make a preliminary build of
mapscript, and then test this same prelim build
(from mapscript/python)
$ python setup.py build
$ ./runalltests
These Python mapscript tests are not the ideal tests of MapServer's C
code, but will improve along with improvements to MapServer's C API
that allow us to shave away the code in the SWIG layer.
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
