Experimental SDE Raster support
Howard Butler
hobu at IASTATE.EDU
Thu Dec 8 14:21:57 EST 2005
I just committed fixups of the layer virtualization issue I was
having with SDE *and* switched off support for SDE rasters. Could
someone comfortable with configure.in magic remove the SDE raster
configuration stuff?
Thanks
Howard
At 12:22 PM 12/8/2005, Steve Lime wrote:
>Off it is!
> >>> Howard Butler <hobu at IASTATE.EDU> 12/08/05 12:06 PM >>>
>My call is to turn it off for now unless someone else wants to be on
>the hook for it ;)
>Howard
>At 11:58 AM 12/8/2005, Frank Warmerdam wrote:
> >On 12/8/05, Howard Butler <hobu at iastate.edu> wrote:
> > > Folks,
> > > I would like to comment out the experimental SDE raster support that
> > > we have in mapsde.c for the time being. As far as I know, I'm the
> > > only one to ever get it to work, it hasn't kept up with the
> > > connection pooling stuff we did, and its utility is quite limited in
> > > comparison to regular gdal-based raster support (projections,
> > > resampling, etc).
> >Howard,
> >Since you would be implicitly on the hook to support
> >it, I think it would be your call.
> >Best regards,
> >I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> >light and sound - activate the windows | http://pobox.com/~warmerdam
> >and watch the world go round - Rush | Geospatial Programmer for Rent
