bad raster layer transform when BBOX is specified within
request (WMS)
Frank Warmerdam
warmerdam at POBOX.COM
Fri Dec 9 12:59:57 EST 2005
On 12/9/05, xslove (sent by Nabble.com) <lists at nabble.com> wrote:
> I successfully configured mapserver as a WMS server. I added raster layer
> into map file. This raster has associated wld file (georeferencing transfrom
> parameters) - image is rotated and sheared. When I send request without BBOX
> parameter it is drawn ok. When BBOX parameter is specified, raster layer is
> drawn bad without rotation and shearing...
XSLove (XSlove? Xslove?),
When you say the raster layer is drawn bad without rotation and
shearing, do you mean that MapServer as rotated the image
and unsheared it to present a rectified north-up view?
That is what should normally happen via WMS. Perhaps
you could provide some small example views to demonstrate
the behavior you are seeing.
I don't know why you would get different effects depending on
whether your WMS request includes a BBOX or not.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
