Revised 4.8 release plan
Steve Lime steve.lime at DNR.STATE.MN.US
Thu Dec 15 12:07:35 EST 2005
I thought what should happen with his syntax would be:
  1) lay down the filled polygon using color
  2) draw a 1 pixel antialiased outline with color
That should work with the current setup. I'll just have to make sure.
Thanks for the feedback!
Steve
>>> "Ed McNierney" <ed at topozone.com> 12/15/05 11:02 AM >>>
Steve -
I'm just about to test your new code from last night, but I used the
same syntax Perry's reporting and I had no problem.
	- Ed
-----Original Message-----
From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
On Behalf Of Steve Lime
Sent: Thursday, December 15, 2005 12:01 PM
To: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-DEV] Revised 4.8 release plan
This new code really shouldn't impact that style definition. I have to
look into it though.
Did that work prior to the new addition?
Steve
>>> "Pericles S. Nacionales" <naci0002 at umn.edu> 12/15/05 10:07 AM >>>
Steve,
LAYER
TYPE POLYGON
TRANSPARENCY ALPHA
CLASS
  STYLE
    COLOR 128 128 128
    ANTIALIAS TRUE   # <-- this causes a segfault
  END
END
When the ANTIALIAS keyword is added in the same style used to define
polygon fill, a segfault occurs.  Is this supposed to work or should an
error be generated for this?
-Perry
On Wednesday 14 December 2005 22:45, Steve Lime wrote:
> Hi Guys: I've made progress and committed a fix for the bug Ed found
> with polygon outlines tonite so basic fuzzy brushes work pretty
> nicely. That said, I really think we should have a beta3 and release
> the first week in January. We should get good feedback with that new
> feature so "beta" status makes sense. Besides getting these brushes in
> the right spots, I'd like to try and figure out this crash Sean is
> seeing with free'ing dynamically created styles, plus I have one other
> bug to fix with rotating pixmap symbols.
> Just my opinion.
> Steve
> >>> Daniel Morissette <dmorissette at DMSOLUTIONS.CA> 12/14/05 8:56 AM
> Steve Lime wrote:
> > Why don't you give me until tomorrow evening and I'll report back.
> Sounds good then. We'll wait to hear back from you.
> Daniel
Conservation Biology Program
University of Minnesota
e-mail: naci0002 at umn.edu
