Fuzzy brushes...
Steve Lime
steve.lime at DNR.STATE.MN.US
Thu Dec 15 12:05:06 EST 2005
Thanks for the feedback. Yes, with last nights modifications the polygon outlines work
too. You can also define simple symbols for applying patterns:
SYMBOL
NAME 'dashed'
TYPE SIMPLE
STYLE 20 20 END
END
and those can use the new brushes. I still need hook into the ELLIPSE brushes though.
As for new parameters, yes I could see some being added for fine tuning brush creation: hardness,
shape (circle, square, diamond) and so on. At this point I thought it better not to add new
keywords and just get the basics working.
I'm really curious about the performance hit...
Steve
>>> Yewondwossen Assefa <assefa at DMSOLUTIONS.CA> 12/15/05 10:27 AM >>>
Steve,
I just tried the antialias on lines and It seems to work well. There
are a couple of quetions that were raised here reagrding this :
* would paremeters like hardness be available at some point for setting ?
I did not yer try it with polygone outlines but I am assuming that It
should work too. Is that correct ?
I will continue the testing in the next days with diffrent features and
report regularly. That for the addition.
Later,
Steve Lime wrote:
>In case anyone would like to test I have hooked up the fuzzy brush generator in mapgd.c for the most trivial line drawing case (no symbol defined). To use:
>1) define a 24-bit output format, IMAGETYPE 'png24' works nicely
>2) define a simple style definition for a line layer (or polygon outline) like so:
> STYLE
> WIDTH 3
> COLOR 255 0 0
> ANTIALIAS TRUE
> END
>3) set TRANSPARENCY ALPHA to enable alpha blending
>Caveats:
> - brushes need to be odd sized. That requirement is enforced in the brush builder which detects even sized requests and rounds up. Symbol scaling should work just fine.
> - you'll notice that the line "fades" in at the start which is due to the transparent nature of the brush. Adjusting the default "hardness" may minimize that.
>That should do it. I will enable for circles layers and other instances where it makes sense (circle symbols, simple symbols with dash patterns and so on) ASAP. I also will enable image cache use in the most simple case which may help performance a bit.
>Note, I hope to do away with 3) (there is a bug filed) but can't yet because of a problem in the image merging code in mapgd.c (not mine old code for a change).
>Steve
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
