Ready for 4.8.0-rc1?
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Thu Dec 22 08:41:25 EST 2005
Steve,
You might want to use my radial lines shapefile for testing label angles
to check out your brushes at all angles.
-Steve W.
Paul Spencer wrote:
> Steve,
> I have a question about fuzzy brushes.  Your test case looks really
> good.  We tried this on our tiger map file in ka-Map and the results
> are less impressive.  It seems to work well for lines that are close  to
> 45 degrees, but for lines that are closer to the vertical or
> horizontal, there is still a noticeable stairstep effect.  Did you  try
> other angles on the line?  From what you said, my understanding  is that
> this could be affected by the default hardness that you have  chosen?
> Cheers
> Paul
> On 22-Dec-05, at 12:08 AM, Daniel Morissette wrote:
>> Our planned date for 4.8.0rc1 is today (Thursday Dec 22nd). Are we
>> good to go? Did you still have work to do on the fuzzy brushes Steve?
>> Daniel
>>  Daniel Morissette               dmorissette at dmsolutions.ca
>>  DM Solutions Group              http://www.dmsolutions.ca/
> |Paul Spencer                           pspencer at dmsolutions.ca   |
> |Applications & Software Development                              |
> |DM Solutions Group Inc                 http://www.dmsolutions.ca/|
