Ready for 4.8.0-rc1?
Steve Lime
steve.lime at DNR.STATE.MN.US
Thu Dec 22 12:07:57 EST 2005
I may still be tweaking the brushes based on comments and ideas from Paul and Steve W.
but the implementation of the brushes is good enough. I have one nagging bug with rotating
pixmaps. GD doesn't honor transparency when pasting rotated image (or so it seems). This
isn't a big problem because the output sucks anyway because GD just uses nearest neighbor
resampling so nobody will use rotated pixmaps.
If you want I can continue to tweak things and cut the release tonite if you're going to be
out and about. Just send me the steps you follow.
Steve
>>> Daniel Morissette <dmorissette at DMSOLUTIONS.CA> 12/21/05 11:08 PM >>>
Our planned date for 4.8.0rc1 is today (Thursday Dec 22nd). Are we good
to go? Did you still have work to do on the fuzzy brushes Steve?
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
