Extra pixel around square vector filler for polygon
Jani Averbach
javerbach at EXTENDTHEREACH.COM
Wed Dec 28 18:54:42 EST 2005
Hello,
I have a map which uses a checkerboard pattern as polygon filler.
The filler is a square which consists of four checks (two white, two black),
and when mapserver renders a polygon using this pattern, it puts an extra
1 pixel wide border for east and north side of square.
I will paste example map file and symbol definition at the end of this email,
so if you have any idea if this is a feature or bug, and how to get rid of this
or what is more appropriate way to draw checkerboard I would be grateful.
BR, Jani
----------------------8<------------------------8<-----------------
SYMBOL
NAME "checkerboard"
TYPE VECTOR
POINTS
0 0
0 1
1 1
1 0
0 0
-99 -99
1 1
1 2
2 2
2 1
1 1
END
FILLED TRUE
END
MAP
SIZE 40 80
SYMBOLSET "symbols/symbols.sym"
EXTENT 0 0 40 80
UNITS METERS
IMAGETYPE PNG
IMAGECOLOR 0 0 0
RESOLUTION 96
LAYER
TYPE POLYGON
STATUS DEFAULT
FEATURE
POINTS
5 44
35 44
35 80
5 80
5 44
END
END
CLASS
STYLE
SYMBOL "checkerboard"
SIZE 16
COLOR 255 255 255
END
END
END
LAYER
TYPE POLYGON
STATUS DEFAULT
FEATURE
POINTS
5 0
35 0
35 36
5 36
5 0
END
END
CLASS
STYLE
SIZE 4
COLOR 255 255 255
END
END
END
END
