Which version of SWIG for 4.8.0 wrappers?
Steve Lime steve.lime at DNR.STATE.MN.US
Sat Dec 31 11:42:18 EST 2005
That was off the top of my head, you're right it's 1.3.21. I've been using 1.3.27 at home and at the DNR but only for Perl (which was probably the most stable) without issues. Have you (or others) exprienced problems with the other bindings with the latest versions? Any reason not to bump the SWIG on the cvs box?
Steve
>>> Sean Gillies <sgillies at FRII.COM> 12/31/05 10:14 AM >>>
1.3.0? I'm pretty sure you have been using at least 1.3.21. The
current release is 1.3.27, and it emits rather different code than
1.3.21. I think most significant changes happened around 1.3.25.
Sean
On Dec 31, 2005, at 9:08 AM, Steve Lime wrote:
> 1.3.0 is what rc1 went out with but I would like to upgrade to the
> latest =
> version of SWIG for anything future.
> Steve
>>>> Sean Gillies <sgillies at FRII.COM> 12/30/05 1:01 PM >>>
> Steve,
> Which version are you going to use to generate the wrappers?
> Sean
