Which version of SWIG for 4.8.0 wrappers?
Sean Gillies
sgillies at FRII.COM
Sat Dec 31 12:39:24 EST 2005
There's nothing in mapscript that requires or takes advantage of
features in swig versions > 1.3.21, so imo we can remain there for
4.8.0. C# users need to use something much more recent, but we have
not been generating wrappers for them in releases up to now.
Sean
On Dec 31, 2005, at 9:42 AM, Steve Lime wrote:
> That was off the top of my head, you're right it's 1.3.21. I've
> been using =
> 1.3.27 at home and at the DNR but only for Perl (which was probably
> the =
> most stable) without issues. Have you (or others) exprienced
> problems with =
> the other bindings with the latest versions? Any reason not to bump
> the =
> SWIG on the cvs box?
> Steve
>>>> Sean Gillies <sgillies at FRII.COM> 12/31/05 10:14 AM >>>
> 1.3.0? I'm pretty sure you have been using at least 1.3.21. The =20
> current release is 1.3.27, and it emits rather different code than =20
> 1.3.21. I think most significant changes happened around 1.3.25.
> Sean
> On Dec 31, 2005, at 9:08 AM, Steve Lime wrote:
>> 1.3.0 is what rc1 went out with but I would like to upgrade to the
>> =20
>> latest =3D
>> version of SWIG for anything future.
>> Steve
>>>>> Sean Gillies <sgillies at FRII.COM> 12/30/05 1:01 PM >>>
>> Steve,
>> Which version are you going to use to generate the wrappers?
>> Sean
