configure issue with debug
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Thu Feb 3 12:13:26 EST 2005
> -----Original Message-----
> From: Frank Warmerdam [mailto:fwarmerdam at gmail.com]
> Sent: Thursday, 03 February, 2005 12:11
> To: Kralidis,Tom [Burlington]
> Cc: MAPSERVER-DEV at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-DEV] configure issue with debug
> On Thu, 3 Feb 2005 11:13:28 -0500, Kralidis,Tom [Burlington]
> <Tom.Kralidis at ec.gc.ca> wrote:
> > Hi,
> > I have a requirement to compile MapServer with debugging
> turned on, so
> > I tried running ./configure with --enable-debug=yes, and got the
> > following
> > error:
> > <snip>
> > checking compiler warnings... basic
> > configure: checking whether we should enable debug features...
> > expr: syntax error
> > ./configure: line 10130: test: too many arguments
> > Enabling debug features: -g in CFLAGS and msDebug()
> to stderr
> > (-DENABLE_STDERR_DEBUG). </snip>
> Tom,
> I believe that --enable / --disable directives to configure
> are not supposed to have any arguments. So just use --enable-debug.
I get the exact same error when I use --enable-debug.
- MapServer CVS
- Linux FC2
..Tom
