mappostgis.c and PostGIS 1.0.0
Jerry Pisk jerry.pisk at GMAIL.COM
Thu Feb 3 12:52:31 EST 2005
I am using mapserver with PostGIS 1.0RC1 and it's working just fine.
But I am only using query and draw features and those are using
OpenGIS Well Known Binary formats.
Jerry
On Thu, 3 Feb 2005 12:44:14 -0500, Kralidis,Tom [Burlington]
<Tom.Kralidis at ec.gc.ca> wrote:
> Hi,
> I've been trying for between mapserver-users and postgis-users to figure
> this one out (I'm starting to feel like one of thoese guys).
> Has anyone successfully tested MapServer CVS with PostGIS 1.0.0RC2?  I'm
> trying to do this, and after much debugging and testing, it looks like
> the MapServer code needs to be updated for the new PostGIS dist.
> Test:
> Here is what's been done successfully:
> - configure PostGIS DB
> - insert sample data
> - fetch sample data via psql
> - configure mapfile to connect with the following:
>  CONNECTIONTYPE postgis
>  CONNECTION "user=postgres dbname=devgeodb"
>  DATA "the_geom from service_resources"
> - Run OGC:WFS GetCapabilities
> - Run OGC:WFS DescribeFeatureType
> - response as expected, I can see the table schema via XML output
> ...when I go to run GetFeature, no data comes back.  DescribeFeatureType
> works, so I know the connection is ok.  I'm wondering if the data
> fetching bindings in PostGIS 1.0.0RC2 have changed, and if MapServer
> needs to update these.
> I'm miffed.
> ..Tom
