mappostgis.c and PostGIS 1.0.0
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Thu Feb 3 14:33:44 EST 2005
Yes, WMS doesn't work either for me.
MapServer CVS
PostGIS 1.0.0RC2
Linux Fedora Core
..Tom
> -----Original Message-----
> From: UMN MapServer Developers List
> [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Paul Ramsey
> Sent: Thursday, 03 February, 2005 13:44
> To: MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-DEV] mappostgis.c and PostGIS 1.0.0
> Has anyone tried mapserver as a WFS against PostGIS of any
> version? I have been trying to figure out how the <Filter>s
> are applied against database backends, perhaps something I
> can do as I loll about in bed this afternoon, but it was not
> immediately clear to me.
> That said, I guess you were also having problems with WMS, right Tom?
> P
> Kralidis,Tom [Burlington] wrote:
> > I've been trying for between mapserver-users and postgis-users to
> > figure this one out (I'm starting to feel like one of thoese guys).
> > Has anyone successfully tested MapServer CVS with PostGIS
> 1.0.0RC2?
> > I'm trying to do this, and after much debugging and
> testing, it looks
> > like the MapServer code needs to be updated for the new
> PostGIS dist.
> > Test:
> > Here is what's been done successfully:
> > - configure PostGIS DB
> > - insert sample data
> > - fetch sample data via psql
> > - configure mapfile to connect with the following:
> > CONNECTIONTYPE postgis
> > CONNECTION "user=postgres dbname=devgeodb"
> > DATA "the_geom from service_resources"
> > - Run OGC:WFS GetCapabilities
> > - Run OGC:WFS DescribeFeatureType
> > - response as expected, I can see the table schema via XML output
> > ...when I go to run GetFeature, no data comes back.
> > DescribeFeatureType works, so I know the connection is ok. I'm
> > wondering if the data fetching bindings in PostGIS 1.0.0RC2 have
> > changed, and if MapServer needs to update these.
> > I'm miffed.
> > ..Tom
