mappostgis.c and PostGIS 1.0.0
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Thu Feb 3 14:40:23 EST 2005
WMS doesn't even work for me. Something's telling me that somethings's
up with the data fetching for MapServer to PostGIS 1.0.0 connections.
..Tom
> -----Original Message-----
> From: UMN MapServer Developers List
> [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Bart van den Eijnden
> Sent: Thursday, 03 February, 2005 13:57
> To: MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-DEV] mappostgis.c and PostGIS 1.0.0
> Hi Paul,
> with Mapserver 4.4.1 and Postgis 0.8 I get:
> [Thu Feb 03 19:57:02 2005] [error] [client 192.168.3.4]
> Premature end of script headers: mapserv.exe [Thu Feb 03
> 19:57:02 2005] [error] [client 192.168.3.4] Thu Feb 03
> 19:57:01 2005 - msAddLine(): Memory allocation error. \r
> WMS works fine, WFS GetFeature fails. WFS DescribeFeatureType works.
> Best regards,
> Bart
> On Thu, 3 Feb 2005 10:44:12 -0800, Paul Ramsey
> <pramsey at REFRACTIONS.NET>
> wrote:
> > Has anyone tried mapserver as a WFS against PostGIS of any
> version? I
> > have been trying to figure out how the <Filter>s are
> applied against
> > database backends, perhaps something I can do as I loll
> about in bed
> > this afternoon, but it was not immediately clear to me.
> > That said, I guess you were also having problems with WMS,
> right Tom?
> > P
> > Kralidis,Tom [Burlington] wrote:
> >> I've been trying for between mapserver-users and postgis-users to
> >> figure this one out (I'm starting to feel like one of thoese guys).
> >> Has anyone successfully tested MapServer CVS with PostGIS
> 1.0.0RC2?
> >> I'm trying to do this, and after much debugging and
> testing, it looks
> >> like the MapServer code needs to be updated for the new
> PostGIS dist.
> >> Test:
> >> Here is what's been done successfully:
> >> - configure PostGIS DB
> >> - insert sample data
> >> - fetch sample data via psql
> >> - configure mapfile to connect with the following:
> >> CONNECTIONTYPE postgis
> >> CONNECTION "user=postgres dbname=devgeodb"
> >> DATA "the_geom from service_resources"
> >> - Run OGC:WFS GetCapabilities
> >> - Run OGC:WFS DescribeFeatureType
> >> - response as expected, I can see the table schema via XML output
> >> ...when I go to run GetFeature, no data comes back.
> >> DescribeFeatureType works, so I know the connection is ok. I'm
> >> wondering if the data fetching bindings in PostGIS 1.0.0RC2 have
> >> changed, and if MapServer needs to update these.
> >> I'm miffed.
> >> ..Tom
> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
