wishlists
Sean Gillies sgillies at FRII.COM
Mon Feb 14 13:40:05 EST 2005
On Feb 14, 2005, at 10:26 AM, Bart van den Eijnden wrote:
> What else is on the lists?
I've got two reasonable items on my list:
* style level (not layer level) feature opacity.
* faster rendering of features from memory using mapscript to reduce
the performance gap between rendering a layer connected to data via a
mapserver connector and rendering features obtained through a scripting
interface to OGR or Postgres.
and one pie-in-the-sky item:
* explore using Cairo instead of GD.  Cairo has the cartoline stuff
built in, and can take advantage of graphic accelerators.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
