wishlists
Frank Warmerdam fwarmerdam at GMAIL.COM
Mon Feb 14 13:15:41 EST 2005
On Mon, 14 Feb 2005 18:26:59 +0100, Bart van den Eijnden
<bartvde at xs4all.nl> wrote:
> What else is on the lists?
Bart,
Nothing too exciting on my lists, but it includes:
 o Support for colorbars so that continuous values (whether
    from a raster or vector attributes) can be assign a color from
    a range without defining a whole set of classes.  likewise, I
    would like to be able to show the colorbar where we would
    normally show the class legend.
 o Reworking features access for query results so that features
    are not normally fetched by id, which can be quite expensive.
 o Rework filtering so that there is a generic filtering format (perhaps
    just the current mapserver expressions) that can be converted
    into each data providers filtering format instead of the current
    approach of custom per-provider FILTER formats.
 o Ensure that WFS passes it's filter spec down to native providers
    to implement efficiently.
 o The ability to hold raster datasources open so that a fastcgi
    mapserver could take advantage of GDAL's in memory caching.
 o Convert mapogr.cpp to C, so that MapServer isn't so tightly
    bound to a particular build of GDAL.  The current C++ interface
    is fragile.
 o Better multi-threading support including making some portions
    re-entrant and finer grained locks in others areas (ie. GDAL/OGR).
Of course, I also wish for stuff like better docs, better testsuites, etc.
Best regards,
