internal server error, lexer problem?
Bart van den Eijnden
bartvde at XS4ALL.NL
Tue Feb 15 08:51:10 EST 2005
Hi list,
Fernando Simon and I have been trying for the last days to debug an
internal server error from Mapserver, without success.
Fernando tests on Linux, with the same Oracle data as I have here, but I
work on Windows.
Before any of the Oracle debug statements make it into the Apache error
log, Mapserver crashes with premature end of script headers. Every
function in maporaclespatial.c has a msDebug call, and debugging is
working in my environment when I do use a valid, working DATA statement.
If I use the following DATA statement:
1. DATA "geom from (SELECT locatie AS geom, naam as NAAM, id AS ID FROM
mrg_gemeenten) using unique id srid 90112 filter version 10g"
Mapserver crashes on Windows. On Linux it works fine.
2. DATA "geom from (SELECT locatie AS geom, id AS ID FROM mrg_gemeenten)
Works fine in both environments.
Could there be a problem with the lexer in this case? On Linux both data
statements work fine.
Any thoughts what we could try?
Thanks in advance.
Best regards,
Bart
