internal server error, lexer problem?
Bart van den Eijnden
bartvde at XS4ALL.NL
Tue Feb 15 08:56:27 EST 2005
Sorry, forgot to mention a few things.
WMS GetMap works fine in both situations (both DATA statements).
WMS GetFeatureInfo crashes with statement 1, statement 2 works fine.
But the problem seems to be that Mapserver crashes before any of the
Oracle functions are called, seeing nothing is in the debug log, and we
can't seem to pinpoint where this could happen. Any pointers to that would
be very much appreciated.
[Tue Feb 15 14:54:33 2005] [error] [client 192.168.3.4] Premature end of
script headers: mapserv.exe
Best regards,
Bart
> Hi list,
> Fernando Simon and I have been trying for the last days to debug an
> internal server error from Mapserver, without success.
> Fernando tests on Linux, with the same Oracle data as I have here, but I
> work on Windows.
> Before any of the Oracle debug statements make it into the Apache error
> log, Mapserver crashes with premature end of script headers. Every
> function in maporaclespatial.c has a msDebug call, and debugging is
> working in my environment when I do use a valid, working DATA statement.
> If I use the following DATA statement:
> 1. DATA "geom from (SELECT locatie AS geom, naam as NAAM, id AS ID FROM
> mrg_gemeenten) using unique id srid 90112 filter version 10g"
> Mapserver crashes on Windows. On Linux it works fine.
> 2. DATA "geom from (SELECT locatie AS geom, id AS ID FROM mrg_gemeenten)
> Works fine in both environments.
> Could there be a problem with the lexer in this case? On Linux both data
> statements work fine.
> Any thoughts what we could try?
> Thanks in advance.
> Best regards,
> Bart
