Bug 1238 committed to CVS (avoid C++/C99 comments in source)
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Thu Feb 17 22:18:23 EST 2005
FYI, I just applied the patch for bug 1238 to CVS. This is the patch
submitted by Petter Reinholdtsen to replace all C++/C99 comments with C
comments in the core source files. The patch was fairly easy to apply,
but I couldn't manually inspect every block of code that was modified,
so I am a bit worried that some block of code could have been disabled
or broken by accident. If you notice odd behaviors with the new CVS
version then please keep this in mind and look for the new comments.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
