Bug 1238 committed to CVS (avoid C++/C99 comments in source)
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Fri Feb 18 13:23:14 EST 2005
Quick followup on this: Petter found a few instances of "http://"
strings that were turned into partly commented lines in mapwcs.c and
mapsvg.c. This is fixed in CVS now.
If you built from CVS this morning then you should probably consider
updating your source again.
Daniel
Daniel Morissette wrote:
> FYI, I just applied the patch for bug 1238 to CVS. This is the patch
> submitted by Petter Reinholdtsen to replace all C++/C99 comments with C
> comments in the core source files. The patch was fairly easy to apply,
> but I couldn't manually inspect every block of code that was modified,
> so I am a bit worried that some block of code could have been disabled
> or broken by accident. If you notice odd behaviors with the new CVS
> version then please keep this in mind and look for the new comments.
> Daniel
> Daniel Morissette dmorissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
