Error in building latest CVS
Steve Lime
steve.lime at DNR.STATE.MN.US
Tue Feb 22 14:20:41 EST 2005
My bad, should've tested the non-GEOS case, I was just so darn happy to
get something working last night I jumped the gun. Having map.h should
not cause problems.
Steve
>>> Daniel Morissette <dmorissette at DMSOLUTIONS.CA> 02/22/05 12:42 PM >>>
Kralidis,Tom [Burlington] wrote:
> Against mapgeos.c:
> usr/local/include -I/usr/local/include -I/usr/local/pgsql/include
> -I/usr/local/include ma
> pgeos.cpp -o mapgeos.o
> mapgeos.cpp:330: error: syntax error before `*' token
> make: *** [mapgeos.o] Error 1
There were a few problems when building without USE_GEOS. I have fixed
them in CVS.
Steve: I moved the #include "map.h" to the top of the file, before the
#ifdef that contains all the other includes. Can you please confirm that
this is not going to cause a problem since map.h used to be included
last and now it's first.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
