FastCGI and HTTP POST
Huub Fleuren
hfl at HOME.NL
Tue Jul 5 12:58:42 EDT 2005
Hi Frank,
In februari you wrote in answer to
>> did anybody test HTTP POST against a Mapserver FastCGI?
>Yikes, I see that FastCGI mode does *not* support post
>mode. If you can file a bug report against this I could
>try and fix it. However, the msIO_* stuff hasn't been used
>much for reading from the stdin pipe so I might end up
>only fixing this in 4.5 to avoid messing up the 4.4.x.
I don't know if anybody really did file a bug, but the code in cutils.c is still the same in 4.6 release.
We worked around it then, but now i 'm wondering if you had the time to look at it.
I will file the bug, as soon as i remember the password
Regards, Huub
<bartvde at xs4all.nl> wrote:
>> Hi list,
>> We are receiving an error message containing "POST body is short" in
>> FastCGI mode, in CGI mode there is no problem.
>> Is HTTP POST supported in FastCGI mode?
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
