FastCGI and HTTP POST
Huub Fleuren
hfl at HOME.NL
Tue Jul 5 13:39:05 EDT 2005
its
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1259
Huub Fleuren wrote:
> Hi Frank,
> In februari you wrote in answer to
>>> did anybody test HTTP POST against a Mapserver FastCGI?
>> Yikes, I see that FastCGI mode does *not* support post
>> mode. If you can file a bug report against this I could
>> try and fix it. However, the msIO_* stuff hasn't been used
>> much for reading from the stdin pipe so I might end up
>> only fixing this in 4.5 to avoid messing up the 4.4.x.
> I don't know if anybody really did file a bug, but the code in
> cutils.c is still the same in 4.6 release.
> We worked around it then, but now i 'm wondering if you had the time
> to look at it.
> I will file the bug, as soon as i remember the password
> Regards, Huub
> <bartvde at xs4all.nl> wrote:
>>> Hi list,
>>> We are receiving an error message containing "POST body is short" in
>>> FastCGI mode, in CGI mode there is no problem.
>>> Is HTTP POST supported in FastCGI mode?
>> Best regards,
>> I set the clouds in motion - turn up | Frank Warmerdam,
>> warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | Geospatial Programmer for Rent
