FastCGI and HTTP POST
Bart van den Eijnden
bartvde at XS4ALL.NL
Tue Jul 5 14:53:55 EDT 2005
Huub,
as you can see in the bug report which was originally filed by me, Frank
commented that he needs a testcase for this one. So if you provide a
testcase for him, it will have a higher chance of getting done I guess.
Best regards,
Bart
On Tue, 05 Jul 2005 19:39:05 +0200, Huub Fleuren <hfl at HOME.NL> wrote:
> its
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1259
> Huub Fleuren wrote:
>> Hi Frank,
>> In februari you wrote in answer to
>>>> did anybody test HTTP POST against a Mapserver FastCGI?
>>> Yikes, I see that FastCGI mode does *not* support post
>>> mode. If you can file a bug report against this I could
>>> try and fix it. However, the msIO_* stuff hasn't been used
>>> much for reading from the stdin pipe so I might end up
>>> only fixing this in 4.5 to avoid messing up the 4.4.x.
>> I don't know if anybody really did file a bug, but the code in cutils.c
>> is still the same in 4.6 release.
>> We worked around it then, but now i 'm wondering if you had the time to
>> look at it.
>> I will file the bug, as soon as i remember the password
>> Regards, Huub
>> <bartvde at xs4all.nl> wrote:
>>>> Hi list,
>>>> We are receiving an error message containing "POST body is short" in
>>>> FastCGI mode, in CGI mode there is no problem.
>>>> Is HTTP POST supported in FastCGI mode?
>>> Best regards,
>>> I set the clouds in motion - turn up | Frank Warmerdam,
>>> warmerdam at pobox.com
>>> light and sound - activate the windows | http://pobox.com/~warmerdam
>>> and watch the world go round - Rush | Geospatial Programmer for Rent
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
