FastCGI and HTTP POST
Huub Fleuren hfl at HOME.NL
Tue Jul 5 15:37:19 EDT 2005
Sorry i forgot that part (as everything else), so the ball lies here for
almost half a year ahem, i forgot about it completely, some projects
have a way of coming back to one.
I'll work on it and  add a documented zip in bugzilla
Huub
Bart van den Eijnden wrote:
> Huub,
> as you can see in the bug report which was originally filed by me,
> Frank  commented that he needs a testcase for this one. So if you
> provide a  testcase for him, it will have a higher chance of getting
> done I guess.
> Best regards,
> Bart
> On Tue, 05 Jul 2005 19:39:05 +0200, Huub Fleuren <hfl at HOME.NL> wrote:
>> its
>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1259
>> Huub Fleuren wrote:
>>> Hi Frank,
>>> In februari you wrote in answer to
>>>>> did anybody test HTTP POST against a Mapserver FastCGI?
>>>> Yikes, I see that FastCGI mode does *not* support post
>>>> mode.  If you can file a bug report against this I could
>>>> try and fix it.  However, the msIO_* stuff hasn't been used
>>>> much for reading from the stdin pipe so I might end up
>>>> only fixing this in 4.5 to avoid messing up the 4.4.x.
>>> I don't know if anybody really did file a bug, but the code in
>>> cutils.c  is still the same in 4.6 release.
>>> We worked around it then, but now i 'm wondering if you had the time
>>> to  look at it.
>>> I will file the bug, as soon as i remember the password
>>> Regards, Huub
>>> <bartvde at xs4all.nl> wrote:
>>>>> Hi list,
>>>>> We are receiving an error message containing "POST body is short" in
>>>>> FastCGI mode, in CGI mode there is no problem.
>>>>> Is HTTP POST supported in FastCGI mode?
>>>> Best regards,
>>>> I set the clouds in motion - turn up   | Frank Warmerdam,
>>>> warmerdam at pobox.com
>>>> light and sound - activate the windows | http://pobox.com/~warmerdam
>>>> and watch the world go round - Rush    | Geospatial Programmer for
>>>> Rent
