How-to start up WCS with SRTM data tile index
Frank Warmerdam
fwarmerdam at GMAIL.COM
Mon Jul 25 20:44:29 EDT 2005
On 7/25/05, Miguel Angel Manso Callejo <m.manso at upm.es> wrote:
> Hello to all,
> I'm trying to start up a WCS with SRTM mission translated from HGT
> format to GTiff int16.
> When i build map file to Mapserver i write:
> LAYER
> NAME srtm
> TYPE RASTER
> DUMP TRUE
> TILEINDEX "tindex.shp"
> TILEITEM "location"
> METADATA
> "wcs_name" "srtm"
> "wcs_label" "SRTM 90m"
> "wcs_formats" "image/geotiff_int16"
> "wcs_nativeformat" "image/geotiff_int16"
> END
> END
> Can any one help me with this dude?
Miguel,
Your tileindex settings look OK. I am including the map file I use
for me SRTM30 server for comparison sake. It doesn't use tileindex,
but does give an example of some other required metadata.
MAP
NAME 'SRTM30PLUS'
EXTENT -180 -90 180 90
UNITS DD
SIZE 600 300
IMAGECOLOR 0 255 0
IMAGETYPE PNG
OUTPUTFORMAT
NAME GEOTIFF_INT16
DRIVER "GDAL/GTiff"
IMAGEMODE INT16
END
PROJECTION
"init=epsg:4326"
END
# Start of web interface definition
WEB
HEADER web/srtmcgi/demo_header.html
TEMPLATE web/srtmcgi/demo.html
FOOTER web/srtmcgi/demo_footer.html
METADATA
"ows_title" "SRTM30Plus Server"
"wcs_label" "SRTM30Plus WCS Server"
"wcs_keywordlist" "WCS,SRTM,DEM,BATHYMETRY"
"wcs_onlineresource" "http://maps.gdal.org/cgi-bin/mapserv_dem"
END
IMAGEURL "/tmp/"
IMAGEPATH "/u/maps/tmp/"
END
LAYER
NAME "srtmplus_raw"
STATUS ON
TYPE RASTER
DATA '/home/warmerda/torrents/data/srtm30plus.tif'
METADATA
wcs_label "SRTM 30 Plus DEM"
ows_title "SRTM 30 Plus DEM (Raw)"
ows_srs "EPSG:4269 EPSG:4326"
ows_extent "-180 -90 180 90"
wcs_resolution "0.00833333 0.00833333"
wcs_formats "GEOTIFF_INT16"
wcs_nativeformat "GeoTIFF"
END
DUMP TRUE
PROJECTION
"init=epsg:4326"
END
END
LAYER
NAME "srtmplus_autoscale"
STATUS ON
TYPE RASTER
PROCESSING "SCALE=AUTO"
METADATA
ows_title "SRTM 30 Plus DEM (autoscaled)"
END
DUMP TRUE
PROJECTION
"init=epsg:4326"
END
END
LAYER
NAME "srtmplus_fixedscale"
STATUS ON
TYPE RASTER
PROCESSING "SCALE=-6000,6000"
METADATA
ows_title "SRTM 30 Plus DEM (fixed scale)"
END
DUMP TRUE
PROJECTION
"init=epsg:4326"
END
END
END
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
