Segmentation fault adding a new layer with php-mapscript (4.6beta3)
Nicol Hermann mapserver at GEOWORLD.DE
Mon Jun 6 10:23:15 EDT 2005
Bill,
Am Montag, den 06.06.2005, 10:19 -0400 schrieb Bill Binko:
> On Mon, 6 Jun 2005, Nicol Hermann wrote:
<cut>
> > Sadly the segfault persists.
> bummer
> > Maybe of note PHP is compiled as cgi with the flag
> > '--with-regex=system'.
> That was what the configure script detected, so that's good.
> At this point, it might not be the regex problem.. could you run it in gdb
> and post the results?  That would show us what the corruption was.
The output of gdb was attached on my first mail.
Here is it again:
gdb php
GNU gdb 6.3-debian
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you
are welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB.  Type "show warranty" for
details.
This GDB was configured as "i386-linux"...Using host libthread_db
library "/lib/libthread_db.so.1".
(gdb) run test.php
Starting program: /usr/local/bin/php test.php
[Thread debugging using libthread_db enabled]
[New Thread 16384 (LWP 6289)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 16384 (LWP 6289)]
0x4114ea30 in layerObj_new (map=0x41f88008) at mapscript_i.c:410
410         map->layerorder[map->numlayers] = map->numlayers;
(gdb)
Many thanks
Nicol
> Bill
