Segmentation fault adding a new layer with php-mapscript (4.6beta3)
Jerry Pisk jerry.pisk at GMAIL.COM
Mon Jun 6 21:50:09 EDT 2005
I don't know if it's related or not but I've just fixed a problem in
mappostgis.c that was responsible for segmentation faults. If your
layers were pulling data from PostGIS please try the latest CVS code.
Just to let everyone know with this fix I was finally able to load and
draw a PostGIS backed map from multiple threads without any crashes.
There were occasional (once every few hundred iterations) GD related
errors but those seemed to be handled properly as errors and didn't
result in crashes. I'm going to send out another e-mail on the subject
later.
Jerry Pisk
On 6/6/05, Daniel Morissette <dmorissette at dmsolutions.ca> wrote:
> Nicol Hermann wrote:
> > Hi List,
> > i 'am trying to build a map from the scratch using php-mapscript and the
> > lastest cvs version.
> > Whenever i add a new layer with
> > $Layer = ms_newLayerObj($map);
> > I receive a segmentation fault.
> FYI I have tried running your script here with the latest from 4.6 CVS
> and the 4.4 CVS branch and in both cases it passes with no errors (other
> than the error drawing the map because I don't have your polygon file).
> I even ran with both versions in Valgrind (memory checker) and it didn't
> detect any problem.
> It could be some specific config option that you use as Bill pointed, or
> it could be something corrupted in your environment. I doubt that's the
> issue here, but one thing to check would be making sure that our
> php_mapscript is compiled with the same GD as your PHP (i.e. that PHP
> doesn't use its builting GD).
> Daniel
>  Daniel Morissette               dmorissette at dmsolutions.ca
>  DM Solutions Group              http://www.dmsolutions.ca/
