Segmentation fault adding a new layer with php-mapscript (4.6beta3)
Bill Binko bill at BINKO.NET
Wed Jun 8 12:37:34 EDT 2005
On Wed, 8 Jun 2005, Steve Lime wrote:
> This is PHP specific I take it, right?
It is: I'm not sure if the other Mapscripts have a similar problem.
Basically, the -DUSE_POINT_Z_M never got passed down when the Makefile in
mapscript/php3 was created by configure.
Someone should probably check the SWIG stuff, but I think Julien's fix
will solve them as well.
Bill
> Steve
> >>> Bill Binko <bill at BINKO.NET> 06/07/05 10:45 AM >>>
> Nicol, Julien
> I found it as well... (bummer we overlapped efforts)
> attached is a patch that you can apply Nicol (run patch < zm.patch from
> the php3 directory) -- or you can grab CVS HEAD after Julien applies his
> Bill
> On Tue, 7 Jun 2005, Julien-Samuel Lacroix wrote:
> > Hi,
> > I found the problem. Thanks for reporting it.
> > I opened bug 1375 to keep track of this issue.
> > The problem was that the USE_POINT_Z_M flag was not carried to mapscript
> > makefile.  This caused mapscript and mapserver to have different mapObj
> > size.
> > Thanks
> > Julien
> > On 06/07/2005 02:42 AM, Nicol Hermann wrote:
> > > Hi Bill, Daniel, and all the others how replied
> > > i could isolate my problem to a single config option.
> > > When i remove the flag:
> > > '--enable-point-z-m'
> > > from the configure line (i need it for oracle spatial) everything works
> > > fine.
> > > When i enable it i get the described segfault.
> > > 0x4114ea30 in layerObj_new (map=0x41f88008) at mapscript_i.c:410
> > > 410         map->layerorder[map->numlayers] = map->numlayers;
> > > (gdb
> > > Could some comment on this or have the same problem?
> > > Many thank
> > > Nicol
