Segmentation fault adding a new layer with php-mapscript (4.6beta3)
Julien-Samuel Lacroix jlacroix at DMSOLUTIONS.CA
Wed Jun 8 12:40:39 EDT 2005
I also modified the java/mapscript Makefile.in to get the flag.
I don't know if the other mapscript need to be updated.
Julien
On 06/08/2005 12:37 PM, Bill Binko wrote:
> On Wed, 8 Jun 2005, Steve Lime wrote:
>>This is PHP specific I take it, right?
> It is: I'm not sure if the other Mapscripts have a similar problem.
> Basically, the -DUSE_POINT_Z_M never got passed down when the Makefile in
> mapscript/php3 was created by configure.
> Someone should probably check the SWIG stuff, but I think Julien's fix
> will solve them as well.
> Bill
>>Steve
>>>>>Bill Binko <bill at BINKO.NET> 06/07/05 10:45 AM >>>
>>Nicol, Julien
>>I found it as well... (bummer we overlapped efforts)
>>attached is a patch that you can apply Nicol (run patch < zm.patch from
>>the php3 directory) -- or you can grab CVS HEAD after Julien applies his
>>Bill
>>On Tue, 7 Jun 2005, Julien-Samuel Lacroix wrote:
>>>Hi,
>>>I found the problem. Thanks for reporting it.
>>>I opened bug 1375 to keep track of this issue.
>>>The problem was that the USE_POINT_Z_M flag was not carried to mapscript
>>>makefile.  This caused mapscript and mapserver to have different mapObj
>>>size.
>>>Thanks
>>>Julien
>>>On 06/07/2005 02:42 AM, Nicol Hermann wrote:
>>>>Hi Bill, Daniel, and all the others how replied
>>>>i could isolate my problem to a single config option.
>>>>When i remove the flag:
>>>>'--enable-point-z-m'
>>>>from the configure line (i need it for oracle spatial) everything works
>>>>fine.
>>>>When i enable it i get the described segfault.
>>>>0x4114ea30 in layerObj_new (map=0x41f88008) at mapscript_i.c:410
>>>>410         map->layerorder[map->numlayers] = map->numlayers;
>>>>(gdb
>>>>Could some comment on this or have the same problem?
>>>>Many thank
>>>>Nicol
Julien-Samuel Lacroix            jlacroix at dmsolutions.ca
DM Solutions Group               http://www.dmsolutions.ca/
