coastline, boundary or lat/lon grid data?
Norman Vine
nhv at CAPE.COM
Thu Jun 9 10:58:41 EDT 2005
Pericles S. Nacionales writes:
> http://www.ngdc.noaa.gov/mgg/shorelines/gshhs.html
> Also, if you have ESRI products, they come with the vector layers you're
> looking for.
Perhaps http://ftp.intevation.de/freegis/worlddata/
FreeGIS Worlddata
These sample geodata have been extracted from VMAP0 R3. To avoid the raster
grids the original data has been processed by grass by reclassifying an
dissolving all polygons. The result is polygon data set with boundaries of
most of the countries of the world.
The the country data of the FreeGIS Worlddata are provided in two version, one
containing the full resolution of the original data. The other one has been
simplified using the Douglas-Peuker algorithm (tolerance value 0.25). The
second one is called country_simpl
HTH
Norman
> Jeff de La Beaujardiere wrote:
> > As far as I can tell, MapServer does not come with any vector data like
> > coastlines, boundaries, or lat/lon grid. I need to provide overlays of
> > such vectors over my satellite imagery as an option. I could get a
> > layer(s) from another WMS, but it would be useful to have and serve that
> > information locally. Data resolution only needs to be good enough for
> > global and regional views.
> > Does anybody have these data in a format that MapServer could support,
> > and ideally the relevant snippet of mapfile? Here are the options in my
> > current build:
> > > ./mapserv -v
> > MapServer version 4.4.2 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> > SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=GDAL INPUT=SHAPEFILE
> > Thanks,
> > Jeff DLB
