workspace in VC++
Brent Fraser
bfraser at GEOANALYTIC.COM
Sun Jun 19 15:05:12 EDT 2005
Luigi,
It basically means compiling the dependencies (zlib, gd, etc), creating a
project, adding the mapserver source files, then setting the location to
dependant libraries.
I found it much easier to edit mapserver's nmake.opt file to set the
location of the dependencies, then use VC++'s nmake on the command line.
There's a few notes in the nmake.opt file on the steps.
I've attached some of my old notes on using the VC++ IDE to compile
mapserver, but since they are out-of-date they are no longer completely
accurate.
Brent Fraser
----- Original Message -----
To: <MAPSERVER-DEV at LISTS.UMN.EDU>
Sent: Wednesday, June 15, 2005 10:56 AM
Subject: [UMN_MAPSERVER-DEV] workspace in VC++
> Hi all
> I am working to get map server workspace in VC++ . Could any one tell
> me the simplest steps to get it ? The methods specified at the map server
> site is giving errors due to depency on libraries ( zlib , gd etc ) . And
> if you have dsw for vc++ 6.0 its most welcome .
> regards thanks in advance
> Luigi
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20050619/ab55e82e/building.htm
