gfs output in Maserver 4.5 using gdal1.2.5
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Mar 9 14:40:04 EST 2005
Steve,
I missed to check bug 950. I guess I should have digged more. I have
tried it and works as described.
Thanks
Steve Lime wrote:
> All: Remember I've been adding some transformation support to WFS output
> as detailed
> in bugs 884 and 950. One of those changes is to allow users to limit
> which items are output
> as part of the GML. Dan and I chatted about this in bug 950. As
> implemented now ALL items
> are excluded from output, you must opt in. This easy to do, just add a
> line like:
> gml_include_items 'all'
> to the layer metadata and magically all items will appear. Please look
> at the text of bug 950
> for an explanation of the transformations that I have put in place.
> Note the transformations
> are only in effect for GML output. I've not had time to tweak
> describeCoverage output yet.
> We may want to tweak these behaviors a bit, but hey, it's a development
> version...
> Steve
>>>>Yewondwossen Assefa <assefa at DMSOLUTIONS.CA> 3/8/2005 3:45:24 PM
> Frank Warmerdam wrote:
>>On Tue, 8 Mar 2005 15:47:48 -0500, Yewondwossen Assefa
>><assefa at dmsolutions.ca> wrote:
>>>Hi There,
>>> I was just testing the wfs output and came accross an issue that I
> do
>>>not really understand. The wfs get feature request produces a gml
> and a
>>>gfs file. In Mapserver 4.4.X (using gdal1-2.5), the gfs contains
>>>attribute informations (<PropertyDefn>) . In Mapserver 4.5
> (gdal1.2.5),
>>>the attributes informations are not included in the file.
>>> Does anyone has a quick explanation on this ? I am using the same
> test
>>>map file in both cases.
>>Assefa,
>>This is using MapServer as a WFS server (not a client), right?
>>I didn't think that MapServer itself would write out a .gfs file to
>>go with a .gml result. My understanding was that .gfs files
>>are only created by OGR when opening a previously unopened
>>gml file.
>>I have done quite a bit of work in GDAL post-1.2.5 to support
>>GML 3 Level 0 schemas, and in this case OGR is not supposed
>>to create a .gfs file. But you mention you are using GDAL 1.2.5
>>in both cases, right?
>>Are the GML files similar?
> Frank,
> I am using Mapserver as a server and a client. That exaplains my
> confusion too : I understand now that Mapserver as a server produces
> the
> gml file and when OGR is used to read the gml (for the wfs client),
> the
> gfs file is created. Both files were created almost at the same and I
> was not really thinking :)
> Your are right about the diffrence in the gml file produced : I just
> checked them and they are effectivly diffrent between 4.4 and 4.5. The
> 4.4 gml had attributes attched to it :
> <gml:featureMember>
> <popplace>
> <gml:boundedBy>
> <gml:Box srsName="EPSG:42304">
> <gml:coordinates>
> 2281604.250000,340848.937500
> </gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> <gml:pointProperty>
> <gml:Point srsName="EPSG:42304">
> <gml:coordinates>2281604.250000,340848.937500</gml:coordinates>
> </gml:Point>
> </gml:pointProperty>
> <AREA>0.000</AREA>
> <PERIMETER>0.000</PERIMETER>
> <POPPLACE_>8</POPPLACE_>
> <POPPLACE_I>1</POPPLACE_I>
> <UNIQUE_KEY>BACMK</UNIQUE_KEY>
> <NAME>Tignish</NAME>
> <NAME_E></NAME_E>
> <NAME_F></NAME_F>
> <UNIQUE_K_1></UNIQUE_K_1>
> <UNIQUE_K_2></UNIQUE_K_2>
> <REG_CODE>11</REG_CODE>
> <NTS50>021I16</NTS50>
> <LAT>465700</LAT>
> <LONG>640200</LONG>
> <SGC_CODE>0</SGC_CODE>
> <CAPITAL>0</CAPITAL>
> <POP_RANGE>1</POP_RANGE>
> </popplace>
> </gml:featureMember>
> The 4.5 version does not have that :
> <gml:featureMember>
> <popplace>
> <gml:boundedBy>
> <gml:coordinates>
> 2499190.000000,194088.234375
> </gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> <gml:pointProperty>
> <gml:coordinates>2499190.000000,194088.234375</gml:coordinates>
> </gml:Point>
> </popplace>
> I guess this quetion to be asked is why the new gml output in
> Mapserver 4.5 does not include the attributes ? Or what should I
> include
> to get the attributes ? I did not follow really closly the new GML
> implementation (maybe I should have :)
> Later,
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
