WFS client problem on Windows 2003, conti nued
Bart van den Eijnden
bartvde at XS4ALL.NL
Mon Mar 14 11:16:57 EST 2005
Hi Ned,
thanks for your reply.
But there is no call in the Mapserver source code to the GetModuleFileName
function, so how could this be the cause?
Best regards,
Bart
On Mon, 14 Mar 2005 09:14:52 -0700, Ned Harding
<nharding at extendthereach.com> wrote:
> No idea if it is related to your problem or not, but if you are using
> IIS on
> Win2003, any calls to GetModuleFileName will prepend "\\?\" to the front
> of
> the path... It caused havok in a bunch of our code until we figured out
> what was going on and striuped it off. You get the same problem with
> IIS on
> XP SP2. See the docs for GetModuleFileName:
> http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dllproc/bas
> e/getmodulefilename.asp
> Ned.
> -----Original Message-----
> From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
> On
> Behalf Of Bart van den Eijnden
> Sent: Monday, March 14, 2005 8:09 AM
> To: MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-DEV] WFS client problem on Windows 2003,
> continued
> Hi list,
> I just got some more info about this. Strangely enough everything works
> fine
> in application (non-CGI) mode, i.e. running mapserv from the command-line
> with QUERY_STRING.
> This is the output created, including libcurl debug output. There is a
> section where the mapserv process waits for a while, but after that
> continues. That section is marked in the output with a lot of *******.
> Does anybody see something strange? Or does somebody see a reason why
> this
> would work in application mode, but not in CGI mode?
> In total there are 3 WFS client layers.
> Thanks in advance.
> Best regards,
> Bart
> On Mon, 14 Mar 2005 14:26:29 +0100, Bart van den Eijnden
> <bartvde at xs4all.nl>
> wrote:
>> Hi list,
>> does anybody have an idea what could be causing the following
>> behaviour in Mapserver WFS client?
>> We were testing a URL to an external WFS service (intranet) on Windows
>> 2003.
>> 1. using the curl utility always the full document is retrieved,
>> although times differ a lot between 10 and 65 seconds
>> 2. Mapserver does not download the full file, it downloads a part of
>> it, and the part that it downloads differs all the time.
>> 3. In IIS 6 a CGI error occurs after a certain time, also this amount
>> of time seems to be irregular. In Apache the same request with the
>> same binary keeps on running, but never finishes. The downloaded GML
>> file remains at a certain size, and no content is added anymore.
>> Any ideas what could cause this would be highly appreciated, or how to
>> go about debugging this problem further.
>> Best regards,
>> Bart
> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
