Patch to fix MAX/MIN error introduced in Bug 1305
Bill Binko
bill at BINKO.NET
Fri May 13 02:55:14 EDT 2005
I made this change a while ago, but it never got applied. Basically, I
added MAX() and MIN() macros not knowing about MS_MAX and MS_MIN, so this
removes them and uses the right ones in msdraw.c
If someone could apply it, I'd appreciate it.
Bill
? 1
? configopts.txt
? mapscriptvars
? maxmin.patch
? nohup.out
? out
? patches
? shp2pdf
? mapscript/java/Makefile
Index: map.h
RCS file: /data2/cvsroot/mapserver/map.h,v
retrieving revision 1.407
diff -U5 -r1.407 map.h
--- map.h 11 May 2005 14:15:16 -0000 1.407
+++ map.h 13 May 2005 06:46:33 -0000
@@ -1933,9 +1933,6 @@
#ifdef __cplusplus
#endif
-#define MAX(a,b) ((a>b) ? a : b)
-#define MIN(a,b) ((a<b) ? a : b)
#endif /* MAP_H */
Index: mapdraw.c
RCS file: /data2/cvsroot/mapserver/mapdraw.c,v
retrieving revision 1.91
diff -U5 -r1.91 mapdraw.c
--- mapdraw.c 11 May 2005 21:45:18 -0000 1.91
+++ mapdraw.c 13 May 2005 06:46:33 -0000
@@ -2004,13 +2004,13 @@
scaledVal = (fieldVal - style->minvalue)/range;
/*At this point, we know where on the range we need to be*/
/*However, we don't know how to map it yet, since RGB(A) can */
/*Go up or down*/
- style->color.red = (int)(MAX(0,(MIN(255, (style->mincolor.red + ((style->maxcolor.red - style->mincolor.red) * scaledVal))))));
- style->color.green = (int)(MAX(0,(MIN(255,(style->mincolor.green + ((style->maxcolor.green - style->mincolor.green) * scaledVal))))));
- style->color.blue = (int)(MAX(0,(MIN(255,(style->mincolor.blue + ((style->maxcolor.blue - style->mincolor.blue) * scaledVal))))));
+ style->color.red = (int)(MS_MAX(0,(MS_MIN(255, (style->mincolor.red + ((style->maxcolor.red - style->mincolor.red) * scaledVal))))));
+ style->color.green = (int)(MS_MAX(0,(MS_MIN(255,(style->mincolor.green + ((style->maxcolor.green - style->mincolor.green) * scaledVal))))));
+ style->color.blue = (int)(MS_MAX(0,(MS_MIN(255,(style->mincolor.blue + ((style->maxcolor.blue - style->mincolor.blue) * scaledVal))))));
style->color.pen = MS_PEN_UNSET; /*so it will recalculate pen*/
/*( "msMapRange(): %i %i %i", style->color.red , style->color.green, style->color.blue);*/
#if ALPHACOLOR_ENABLED
