is CVS down?
Daniel Morissette dmorissette at DMSOLUTIONS.CA
Fri May 13 12:21:00 EDT 2005
Daniel Morissette wrote:
> Kralidis,Tom [Burlington] wrote:
>> I still can't access.  Anyone else have the same issue?
> Works for me at the moment.
BTW, if the problem persists, there is now a mirror of the MapServer CVS
on maptools.org (it's just been setup a week or two ago). Files should
*NOT* be committed to that CVS server or they will be lost, but you can
use it to get the latest source, it's updated every 15 minutes from the
master if I remember correctly.
The CVSROOT is
  CVSROOT=:pserver:cvs at cvs.maptools.org:/cvs/mapserver/cvsroot
Use the same login/pass as the master CVS.
Daniel
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
