PHP Mapscript fixes for 4.6.0-beta2
Mark Cave-Ayland
m.cave-ayland at WEBBASED.CO.UK
Fri May 27 04:27:15 EDT 2005
Hi Bart,
Thanks for the advice, I wasn't sure exactly what to do with proposed
patches. I've just created an entry in Bugzilla for this
(http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1367) and uploaded the
files contained in the original email.
Many thanks,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
> -----Original Message-----
> From: Bart van den Eijnden [mailto:BEN at Syncera-ITSolutions.NL]
> Sent: 27 May 2005 08:10
> To: MAPSERVER-DEV at LISTS.UMN.EDU; Mark Cave-Ayland (External)
> Subject: Re: [UMN_MAPSERVER-DEV] PHP Mapscript fixes for 4.6.0-beta2
> Hi Mark,
> it might be the best idea to open up a bug report per fix in
> the Mapserver bugzilla so these patches don't get lost.
> I also don't know what the policy is for keeping SWIG
> mapscript in sync with PHP/Mapscript, so your changes might
> need changes in the SWIG mapscript as well.
> Best regards,
> Bart
> Syncera-ITSolutions
> Postbus 270
> 2600 AG DELFT
> tel.nr.: 015-7512436
> email: BEN at Syncera-ITSolutions.nl
> >>> Mark Cave-Ayland <m.cave-ayland at WEBBASED.CO.UK> 05/26/05
> 03:08pm >>>
> Hi everyone,
> I've just been looking at dynamically creating symbols on the
> fly using PHP Mapscript, and found a couple of bugs which I
> believe I have fixed with the attached patches. The patches
> are against the file mapserver-4.6.0-beta2.tar.gz which I
> downloaded from http://mapserver.gis.umn.edu.
> 1) symbolObj has no imagepath property
> This was fixed by copying the code from mapsymbol.c
> to allow the imagepath property to be set via mapscript. I
> was a little unsure about how the current path should
> be handled, so at the moment it assumes that the path to the
> GIF/PNG is absolute without considering the current
> path from the environment.
> 2) symbolObj->setPoints() doesn't correctly set
> symbolObj->sizex/sizey
> Using setPoints() to load an array of points for a
> vector symbol was not correctly setting sizex/sizey to the
> maximum extents of the symbol. Hence all symbols were
> being drawn with a size of 0 and did not appear to be
> visible. This was fixed by borrowing the code from
> mapsymbol.c to set sizex/sizey to the maximum extents of the
> symbol as points are added to the symbol.
> Many thanks,
> Mark.
> WebBased Ltd
> 17 Research Way
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
