formatting of BoundingBox coordinates (mapows.c)
Martin Kofahl
martin.kofahl at UNI-ROSTOCK.DE
Fri Nov 4 07:01:38 EST 2005
I have had some troubles with a WMS client connection mapserv last time.
Reason was the formatting of the <BoundingBox SRS=> tag in the
capabilities document - numbers were written as 1.11111e+06. As I
changed to floating (see below), the application worked.
Question: is there a special reason for formatting the BoundingBox as
exponents? Could you change it?
Changes I made in mapows.c:
1206c1206
< msIO_fprintf(stream, "%s<%s minx=\"%f\" miny=\"%f\" maxx=\"%f\"
maxy=\"%f\" />\n",
> msIO_fprintf(stream, "%s<%s minx=\"%g\" miny=\"%g\" maxx=\"%g\"
maxy=\"%g\" />\n",
1231c1231
< "%s minx=\"%f\" miny=\"%f\" maxx=\"%f\"
maxy=\"%f\"",
> "%s minx=\"%g\" miny=\"%g\" maxx=\"%g\"
maxy=\"%g\"",
Thank you!
Martin
Universität Rostock
Agrar- und Umweltwissenschaftliche Fakultät
Geodäsie und Geoinformatik
Martin Kofahl
Justus-v.-Liebig Weg 6 / Zimmer 72
18059 Rostock
Tel. +49 381 498 2165
Fax. +49 381 498 2188
martin.kofahl at uni-rostock.de
http://www.auf.uni-rostock.de/
http://www.auf.uni-rostock.de/gg/
