New User question
Steve Lime
steve.lime at DNR.STATE.MN.US
Wed Nov 16 13:39:54 EST 2005
Sean: Couple of things. First, the path to the mapfile *must* be full path (i.e. including c:\web) and
second, questions like these really belong on mapserver-users...
Steve
>>> Sean Montague <scene at THEMOUNTAINSCENE.COM> 11/15/05 1:08 PM >>>
I installed mapserver on windows XP with ms441pg.zip and I am working
through the tutorial. I am running Apache, and my localhost folder is
C:\web and mapserver located at C:\web\mapserver\. I'm trying to load a
shape file to get started, so I copied the example1-1.map and modified
it,correctly I hope. When I use the url modified for my computer I get:
"msLoadMap(): Unable to access file.
(/mapserver/apps/tutorial/htdocs/example1-1.map) "
url:
http://localhost/cgi-bin/mapserv.exe?map=/mapserver/apps/tutorial/htdocs/example1-1.map&layer=roads&mode=map
Am I missing something? My map file is below. Thanks.
Sean
MAP
IMAGETYPE JPEG
EXTENT 482565 4392206 488236 4396914
SIZE 400 300
SHAPEPATH "/mapserver/apps/tutorial/data"
IMAGECOLOR 255 255 255
LAYER # States polygon layer begins here
NAME roads
DATA rds2
STATUS OFF
TYPE POLYGON
CLASS
NAME "My Roads"
STYLE
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END
END
END
