Will PHP-Mapscript support OWSRequests?
Frank Warmerdam warmerdam at POBOX.COM
Tue Oct 4 09:30:19 EDT 2005
On 10/4/05, Sebastian Albrecht <albrecht at fielax.de> wrote:
> Question 1:
> Will PHP-Mapscript support a SWIG-Mapscript-like OWSRequest at some
> point in the future or is it foreseeable PHP- and SWIG-Mapscript will
> differ more and more?
Sebastian,
I will leave the above for the PHP gurus to answer.
> Question 2:
> Will PHP-Mapscript support a special drawing function which ignores the
> aspect ratio of width/height and does not adjust the extent?
This can be forced by setting the CONFIG option MS_NONSQUARE to
YES in your .map file.  Does PHP MapScript provide a mechanism to set
config options for the map?
Best regards,
