QUERY on layers with SIZEITEM/ANGLEITEM causes crash
Karsten Hoffmann karhof at WEB.DE
Fri Oct 7 06:54:26 EDT 2005
I don’t use labels in my layers, so I think my problem doesn’t relate to bug 1398. It’s probably a problem with drawing the querymap. I can file a new bug on this with an example.
Karsten
thomas bonfort <thomas.bonfort at GMAIL.COM> schrieb am 07.10.05 10:00:02:
> Does your map contain labels? If so, supposing you're only drawing the
> layer that is causing the problem, does the crash disappear if you
> disable labels?
> All these questions relate to bug
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1398 , the proposed
> patch fixed the issue for me.
> cheers
> tb
> On 10/6/05, Karsten Hoffmann <karhof at web.de> wrote:
> > You are right. I'm using querymaps too. The query works without them. But if I want to have querymaps mapserver crashes.
> > Karsten
> > Steve Lime <steve.lime at DNR.STATE.MN.US> schrieb am 06.10.05 23:00:38:
> > > And draws work ok? Are you doing query maps? I can't see how any style settings would affect queries. Query maps perhaps, but not queries themselves. Please file a bug...
> > > Steve
> > > >>> Karsten Hoffmann <karhof at WEB.DE> 10/06/05 2:54 PM >>>
> > > Hi,
> > > Mapserver crashes if I do a query (query or nquery) on a layer (point or polygon) which includes SIZEITEM and/or ANGLEITEM in the STYLE-Object.
> > > For example I have a layer with filled circles in one CLASS where the size varies with SIZEITEM. If I click on a circle in the query (or nquery) mode then mapserver hangs up.
> > > I get an "Internal Server Error".
> > > This happens also in a point-layer with ANGLEITEM and in a polygon-layer with SYMBOL HATCH and SIZEITEM.
> > > The Apache error.log says:
> > > Premature end of script headers: mapserv_46.exe, referer: http://localhost/cgi-bin/mapserv_46.exe?map=c%3A%2Fms4w%2Fapache%2Fhtdocs%2Fdiplom%2Fberlin2.map&imgext=368711.000000+5798131.680435+417394.300000+5838348.319565&imgxy=230.0+190.0&mode=browse&zoomdir=0&zoomsize=2&layer=ewabs3_orte
> > > Does anyone know this problem?
> > > I'm using MapServer 4.6.1 (in ms4w 1.2.2) on Windows XP.
> > > Best regards,
> > > Karsten Hoffmann
> > > ______________________________________________________________
> > > Verschicken Sie romantische, coole und witzige Bilder per SMS!
> > > Jetzt bei WEB.DE FreeMail: http://f.web.de/?mc=021193
> > ______________________________________________________________________
> > XXL-Speicher, PC-Virenschutz, Spartarife & mehr: Nur im WEB.DE Club!
> > Jetzt gratis testen! http://freemail.web.de/home/landingpad/?mc=021130
