QUERY on layers with SIZEITEM/ANGLEITEM causes crash
thomas bonfort
thomas.bonfort at GMAIL.COM
Fri Oct 7 03:47:25 EDT 2005
Does your map contain labels? If so, supposing you're only drawing the
layer that is causing the problem, does the crash disappear if you
disable labels?
All these questions relate to bug
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1398 , the proposed
patch fixed the issue for me.
cheers
tb
On 10/6/05, Karsten Hoffmann <karhof at web.de> wrote:
> You are right. I'm using querymaps too. The query works without them. But if I want to have querymaps mapserver crashes.
> Karsten
> Steve Lime <steve.lime at DNR.STATE.MN.US> schrieb am 06.10.05 23:00:38:
> > And draws work ok? Are you doing query maps? I can't see how any style settings would affect queries. Query maps perhaps, but not queries themselves. Please file a bug...
> > Steve
> > >>> Karsten Hoffmann <karhof at WEB.DE> 10/06/05 2:54 PM >>>
> > Hi,
> > Mapserver crashes if I do a query (query or nquery) on a layer (point or polygon) which includes SIZEITEM and/or ANGLEITEM in the STYLE-Object.
> > For example I have a layer with filled circles in one CLASS where the size varies with SIZEITEM. If I click on a circle in the query (or nquery) mode then mapserver hangs up.
> > I get an "Internal Server Error".
> > This happens also in a point-layer with ANGLEITEM and in a polygon-layer with SYMBOL HATCH and SIZEITEM.
> > The Apache error.log says:
> > Premature end of script headers: mapserv_46.exe, referer: http://localhost/cgi-bin/mapserv_46.exe?map=c%3A%2Fms4w%2Fapache%2Fhtdocs%2Fdiplom%2Fberlin2.map&imgext=368711.000000+5798131.680435+417394.300000+5838348.319565&imgxy=230.0+190.0&mode=browse&zoomdir=0&zoomsize=2&layer=ewabs3_orte
> > Does anyone know this problem?
> > I'm using MapServer 4.6.1 (in ms4w 1.2.2) on Windows XP.
> > Best regards,
> > Karsten Hoffmann
> > ______________________________________________________________
> > Verschicken Sie romantische, coole und witzige Bilder per SMS!
> > Jetzt bei WEB.DE FreeMail: http://f.web.de/?mc=021193
> ______________________________________________________________________
> XXL-Speicher, PC-Virenschutz, Spartarife & mehr: Nur im WEB.DE Club!
> Jetzt gratis testen! http://freemail.web.de/home/landingpad/?mc=021130
