MS RFC 3: Status update
Frank Warmerdam
warmerdam at POBOX.COM
Thu Oct 27 22:11:41 EDT 2005
On 10/27/05, Jani Averbach <javerbach at extendthereach.com> wrote:
> So could you review/test your favorite layer, and send follow up to
> the list when you have found it good to go. I will then update
> MS-RFC-3 to contain these notes, thanks.
Jani / Assefa,
There was a problem in mapogcfilter.c. I have changed this:
int FLTApplyFilterToLayer(FilterEncodingNode *psNode, mapObj *map,
int iLayerIndex, int bOnlySpatialFilter)
if ( ! layer->vtable) {
int rv = msInitializeVirtualTable(layer);
if (rv != MS_SUCCESS)
return rv;
return layer->vtable->LayerApplyFilterToLayer(psNode, map,
iLayerIndex,
bOnlySpatialFilter);
to this:
layerObj *layer = map->layers + iLayerIndex;
return rv;
iLayerIndex,
The code compiles now and seems OK, but I don't know how
to test it, so let me know if I patched it up wrong.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
