MS RFC 3: Status update
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Fri Oct 28 10:10:31 EDT 2005
The fix seems to be ok. I am running few tests on the filter encoding
and will report any problems.
Later,
Frank Warmerdam wrote:
> On 10/27/05, Jani Averbach <javerbach at extendthereach.com> wrote:
>>So could you review/test your favorite layer, and send follow up to
>>the list when you have found it good to go. I will then update
>>MS-RFC-3 to contain these notes, thanks.
> Jani / Assefa,
> There was a problem in mapogcfilter.c. I have changed this:
> int FLTApplyFilterToLayer(FilterEncodingNode *psNode, mapObj *map,
> int iLayerIndex, int bOnlySpatialFilter)
> if ( ! layer->vtable) {
> int rv = msInitializeVirtualTable(layer);
> if (rv != MS_SUCCESS)
> return rv;
> return layer->vtable->LayerApplyFilterToLayer(psNode, map,
> iLayerIndex,
> bOnlySpatialFilter);
> to this:
> layerObj *layer = map->layers + iLayerIndex;
> return rv;
> iLayerIndex,
> The code compiles now and seems OK, but I don't know how
> to test it, so let me know if I patched it up wrong.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
