Mapserver compilation with mygis on windows
Carsten M ünchenbach map at HYDRARGYRUM.DE
Mon Sep 5 05:40:41 EDT 2005
That's what I did: I'm sorry that I forgot to give you copies of the file:
That's the path to MySQL Version 3.23.58 binary distribution, installed and
works
C:\projects\mysql
here the concerning rows:
in NMAKE.opt
#MYGIS
MYGIS_DIR = c:\projects\mysql
MYGIS=-DUSE_MYGIS
#MyGIS support
!IFDEF MYGIS
MYGIS_INC=-I$(MYGIS_DIR)\include
MYGIS_LIB=$(MYGIS_DIR)\lib\opt\libmysql.lib "C:\Programme\Microsoft Visual
Studio\VC98\Lib\advapi32.lib"
!ENDIF
EXTERNAL_LIBS=$(GD_LIBS) $(TIFF_LIB) $(JPEG_LIB) \
     $(PROJ_LIB) $(OGR_LIB) $(GDAL_LIB)\
     $(CURL_LIB)  $(MING_LIB) $(PDF_LIB) \
     $(WINSOCK_LIB) $(POSTGIS_LIB) $(IMGGEN_LIB) $(ERR_LIB) \
     $(ORACLE_LIB) $(MYGIS_LIB) $(SDE_LIB) $(ICONV_LIB) $(FCGILIB)
LIBS=$(MS_LIB) $(EXTERNAL_LIBS)
LIBS_DLL=$(MS_LIB_DLL) $(EXTERNAL_LIBS)
INCLUDES=$(GD_INC) $(TIFF_INC) $(JPEG_INC)  \
         $(PROJ_INC) $(REGEX_INC) $(GDAL_INC) $(OGR_INC) \
         $(CURL_INC) $(MING_INC) $(PDF_INC) $(POSTGIS_INC) \
         $(IMGGEN_INC) $(ERR_INC) $(ORACLE_INC) $(MYGIS_INC) $(SDE_INC)\
         $(ICONV_INC) $(FCGIINC)
MS_DEFS = $(REGEX_OPT) $(STRINGS) $(POSTGIS)  -DWIN32 -D_WIN32 \
          $(EPPL) $(PROJ) $(TIFF) $(JPEG) $(GD) $(OGR) $(WMS) $(THREADS) \
          $(WMSCLIENT) $(MING) $(IGNORE_MISSING_DATA)
$(NEED_NONBLOCKING_STDERR) $(ENABLE_STDERR_DEBUG) \
          $(USE_POINT_Z_M) $(GDAL) $(FCGIDEF) \
          $(WFS) $(WFSCLIENT) $(WCS) $(PDF) $(EGIS) \
        $(USE_GD_ANTIALIAS) $(ORACLE) $(MYGIS) $(MING_VERSION) $(SDE_OPT)
$(ICONV)
MS_CFLAGS=$(INCLUDES) $(MS_DEFS)
But still the same error. I looked up the mapjoin.c file at row 486
#ifndef _mysql_h
#include <mysql/mysql.h>
#endif
I don't know why _mysql_h is not defined.
If I change it to
#ifndef _mysql_h
#include <c:\projects\mysql\include\mysql.h>
#endif
with my Path, mysql.h is found but the errors getting even more worse:
c:\projects\mysql\include\mysql_com.h(117) : error C2061: Syntaxfehler :
Bezeichner 'SOCKET'
c:\projects\mysql\include\mysql_com.h(132) : error C2059: Syntaxfehler : '}'
c:\projects\mysql\include\mysql_com.h(162) : error C2143: Syntaxfehler :
Fehlendes ')' vor '*'
Fehlendes '{' vor '*'
a.s.o.
such syntax error in the mysql files that just can't be. I use the binary
distribution for windows.
Thanks for your help so far,
Carsten
On Mon, 5 Sep 2005 11:00:04 +0200, Bart van den Eijnden
<BEN at SYNCERA-ITSOLUTIONS.NL> wrote:
>You need to download mysql and set the correct path in nmake.opt.
>Best regards,
>Bart
>Syncera IT Solutions
>Postbus 270
>2600 AG  DELFT
>tel.nr.: 015-7512436
>email: BEN at Syncera-ITSolutions.nl
>>>> =?ISO-8859-15?Q?Carsten_M=FCnchenbach?= <map at HYDRARGYRUM.DE> 09/05/05
10:43 am >>>
>Hi all,
>I manage to get MapSeerver compiled on Windows XP. It works fine without
>the mygis option. But know I urgently need MapServer with MyGIS support.
>Unfortunately I'm running into an error:
>cl /nologo /MD /W3 /DDEBUG -Ic:/projects/gdwin32 -Ic:\projects\proj-
>4.4.9/src -Ic:\projects\php-4.3.11/regex -DPHP_NO_ALIASES
>-Ic:\projects\gdal-1.2.6/gcore -Ic:\projects\gdal-1.2.6/alg
>-Ic:\projects\gdal-1.2.6/ogr -Ic:\projects\gdal-1.2.6/port
>-Ic:\projects\gdal-1.2.6/ogr/ogrsf_frmts -Ic:\projects\gdal-1.2
>.6/ogr -Ic:\projects\gdal-1.2.6/port  -Ic:/projects/curl-7.14.0/include
>  -Ic:/projects/pdflib-6.0.0/pdflib      -Ic:\projects\mysql\include
>-DHAVE_STRING_H -DREGEX_MALLOC -DNEED_STRCASECMP -DNEED_STRNCASECMP
>-DNEED_STRLCAT   -DWIN32 -D_WIN32   -DUSE_PROJ -DUSE_PROJ_API_H
>-DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_GIF
>-DGD_HAS_GDIMAGEGIFPTR -DUSE_GD_FT -DGD_HAS_GETBITMAPFONT -DUSE_OGR
>-DUSE_WMS_SVR   -DUSE_WMS_LYR  -DIGNORE_MISSING_DATA
>-DENABLE_STDERR_DEBUG   -DUSE_GDAL   -DUSE_WFS_SVR -DUSE_WFS_LYR
>-DUSE_WCS_SVR -DUSE_PDF   -DUSE_GD_ANTIALI
>AS  -DUSE_MYGIS    /c mapjoin.c /Fomapjoin.obj
>mapjoin.c
>mapjoin.c(486) : fatal error C1083: Include-Datei kann nicht geoeffnet
>werden: 'mysql/mysql.h': No such file or directory
>NMAKE : fatal error U1077: 'cl' : Rueckgabe-Code '0x2'
>What's going wrong? Ideas are ver appreciated!
>Thanks,
>Carsten
