Mapserver compilation with mygis on windows
Andreas Albarello andreas.albarello at TERRITORIUMONLINE.COM
Mon Sep 5 06:54:33 EDT 2005
Carsten,
you may try to replace
#ifndef _mysql_h
#include <c:\projects\mysql\include\mysql.h>
#endif
with the following:
#ifndef _mysql_h
#include <winsock.h>
#endif
Hope this helps.
Best regards,
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Siemens-Straße 19 - I 39100 Bolzano/Bozen
email: andreas.albarello at territoriumonline.com
web:   www.territoriumonline.com
Carsten Münchenbach wrote:
> That's what I did: I'm sorry that I forgot to give you copies of the file:
> That's the path to MySQL Version 3.23.58 binary distribution, installed and
> works
> C:\projects\mysql
> here the concerning rows:
> in NMAKE.opt
> #MYGIS
> MYGIS_DIR = c:\projects\mysql
> MYGIS=-DUSE_MYGIS
> #MyGIS support
> !IFDEF MYGIS
> MYGIS_INC=-I$(MYGIS_DIR)\include
> MYGIS_LIB=$(MYGIS_DIR)\lib\opt\libmysql.lib "C:\Programme\Microsoft Visual
> Studio\VC98\Lib\advapi32.lib"
> !ENDIF
> EXTERNAL_LIBS=$(GD_LIBS) $(TIFF_LIB) $(JPEG_LIB) \
>      $(PROJ_LIB) $(OGR_LIB) $(GDAL_LIB)\
>      $(CURL_LIB)  $(MING_LIB) $(PDF_LIB) \
>      $(WINSOCK_LIB) $(POSTGIS_LIB) $(IMGGEN_LIB) $(ERR_LIB) \
>      $(ORACLE_LIB) $(MYGIS_LIB) $(SDE_LIB) $(ICONV_LIB) $(FCGILIB)
> LIBS=$(MS_LIB) $(EXTERNAL_LIBS)
> LIBS_DLL=$(MS_LIB_DLL) $(EXTERNAL_LIBS)
> INCLUDES=$(GD_INC) $(TIFF_INC) $(JPEG_INC)  \
>          $(PROJ_INC) $(REGEX_INC) $(GDAL_INC) $(OGR_INC) \
>          $(CURL_INC) $(MING_INC) $(PDF_INC) $(POSTGIS_INC) \
>          $(IMGGEN_INC) $(ERR_INC) $(ORACLE_INC) $(MYGIS_INC) $(SDE_INC)\
>          $(ICONV_INC) $(FCGIINC)
> MS_DEFS = $(REGEX_OPT) $(STRINGS) $(POSTGIS)  -DWIN32 -D_WIN32 \
>           $(EPPL) $(PROJ) $(TIFF) $(JPEG) $(GD) $(OGR) $(WMS) $(THREADS) \
>           $(WMSCLIENT) $(MING) $(IGNORE_MISSING_DATA)
> $(NEED_NONBLOCKING_STDERR) $(ENABLE_STDERR_DEBUG) \
>           $(USE_POINT_Z_M) $(GDAL) $(FCGIDEF) \
>           $(WFS) $(WFSCLIENT) $(WCS) $(PDF) $(EGIS) \
>         $(USE_GD_ANTIALIAS) $(ORACLE) $(MYGIS) $(MING_VERSION) $(SDE_OPT)
> $(ICONV)
> MS_CFLAGS=$(INCLUDES) $(MS_DEFS)
> But still the same error. I looked up the mapjoin.c file at row 486
> #ifndef _mysql_h
> #include <mysql/mysql.h>
> #endif
> I don't know why _mysql_h is not defined.
> If I change it to
> #ifndef _mysql_h
> #endif
> with my Path, mysql.h is found but the errors getting even more worse:
> c:\projects\mysql\include\mysql_com.h(117) : error C2061: Syntaxfehler :
> Bezeichner 'SOCKET'
> c:\projects\mysql\include\mysql_com.h(132) : error C2059: Syntaxfehler : '}'
> c:\projects\mysql\include\mysql_com.h(162) : error C2143: Syntaxfehler :
> Fehlendes ')' vor '*'
> Fehlendes '{' vor '*'
> a.s.o.
> such syntax error in the mysql files that just can't be. I use the binary
> distribution for windows.
> Thanks for your help so far,
> Carsten
> On Mon, 5 Sep 2005 11:00:04 +0200, Bart van den Eijnden
> <BEN at SYNCERA-ITSOLUTIONS.NL> wrote:
>>You need to download mysql and set the correct path in nmake.opt.
>>Best regards,
>>Bart
>>Syncera IT Solutions
>>Postbus 270
>>2600 AG  DELFT
>>tel.nr.: 015-7512436
>>email: BEN at Syncera-ITSolutions.nl
>>>>>=?ISO-8859-15?Q?Carsten_M=FCnchenbach?= <map at HYDRARGYRUM.DE> 09/05/05
> 10:43 am >>>
>>Hi all,
>>I manage to get MapSeerver compiled on Windows XP. It works fine without
>>the mygis option. But know I urgently need MapServer with MyGIS support.
>>Unfortunately I'm running into an error:
>>cl /nologo /MD /W3 /DDEBUG -Ic:/projects/gdwin32 -Ic:\projects\proj-
>>4.4.9/src -Ic:\projects\php-4.3.11/regex -DPHP_NO_ALIASES
>>-Ic:\projects\gdal-1.2.6/gcore -Ic:\projects\gdal-1.2.6/alg
>>-Ic:\projects\gdal-1.2.6/ogr -Ic:\projects\gdal-1.2.6/port
>>-Ic:\projects\gdal-1.2.6/ogr/ogrsf_frmts -Ic:\projects\gdal-1.2
>>.6/ogr -Ic:\projects\gdal-1.2.6/port  -Ic:/projects/curl-7.14.0/include
>> -Ic:/projects/pdflib-6.0.0/pdflib      -Ic:\projects\mysql\include
>>-DHAVE_STRING_H -DREGEX_MALLOC -DNEED_STRCASECMP -DNEED_STRNCASECMP
>>-DNEED_STRLCAT   -DWIN32 -D_WIN32   -DUSE_PROJ -DUSE_PROJ_API_H
>>-DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_GIF
>>-DGD_HAS_GDIMAGEGIFPTR -DUSE_GD_FT -DGD_HAS_GETBITMAPFONT -DUSE_OGR
>>-DUSE_WMS_SVR   -DUSE_WMS_LYR  -DIGNORE_MISSING_DATA
>>-DENABLE_STDERR_DEBUG   -DUSE_GDAL   -DUSE_WFS_SVR -DUSE_WFS_LYR
>>-DUSE_WCS_SVR -DUSE_PDF   -DUSE_GD_ANTIALI
>>AS  -DUSE_MYGIS    /c mapjoin.c /Fomapjoin.obj
>>mapjoin.c
>>mapjoin.c(486) : fatal error C1083: Include-Datei kann nicht geoeffnet
>>werden: 'mysql/mysql.h': No such file or directory
>>NMAKE : fatal error U1077: 'cl' : Rueckgabe-Code '0x2'
>>What's going wrong? Ideas are ver appreciated!
>>Thanks,
>>Carsten
