MS RFC: Layer Plug-in Architecture
Frank Warmerdam
fwarmerdam at GMAIL.COM
Thu Sep 8 11:49:23 EDT 2005
On 9/8/05, Jani Averbach <javerbach at extendthereach.com> wrote:
> i) It should be possible generate on the fly layers, existing
> mapscripts are doing this.
Jani,
Generating on-the-fly layers is quite important!
> To get this really working and to prevent bugs, we should not let
> users to edit directly layer.connectiontype, so it should be removed
> or make read-only from scripting interface.
I think it would be reasonably to require update of the connection
type via a function instead of direct manipulation even though this
might result in some disruption to existing mapscript applications.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
