MS RFC: Layer Plug-in Architecture
Sean Gillies
sgillies at FRII.COM
Thu Sep 8 12:14:27 EDT 2005
I was chatting with Jani on #mapserver yesterday, and here's my
perspective:
On Sep 8, 2005, at 9:38 AM, Jani Averbach wrote:
> Objectives:
> i) It should be possible generate on the fly layers, existing
> mapscripts are doing this.
> ii) It should be possible to change on the fly the type of the
> existing layer, existing mapscripts are doing this.
> First objective (generate layer on-the-fly), Solution:
> Delay load layer's vtable when layer's function interface is used
> first time. No additional vtable initialization is needed when you
> create a layer.
Fine with me.
> Second objective (mutate existing layer), First solution:
> Add an extra field to the vtable, which also tells connection type.
> Then add to the layers interface functions a logic that if vtable's
> and layer's connection type are different, then on-the-fly switch
> vtable to reflect layer's connectiontype.
> This solution will bring few consequences:
> - Per every layer function call we have to do few extra check
> - For custom layer functionality, we have to provide an encapsulated
> interface to change from one custom layer to another because for
> different custom layers, the connectiontype is same i.e. CUSTOM,
> and the actual information which library and hence backend to use,
> is stored elsewhere in the layer.
> Second objective, Second solution:
> Require that you can't directly change connection type and provide a
> function for this operation.
> int ChangeConnectionType(int type, const char *library_str)
> where type is connection type and library_str is a path to the dynamic
> library to load, if custom type. For internal types this second
> argument
> is NULL.
> To get this really working and to prevent bugs, we should not let
> users to edit directly layer.connectiontype, so it should be removed
> or make read-only from scripting interface.
> Second objective, Third solution:
> Remove this feature and don't let users mutate existing layers.
Now that I think of it, I *do* allow something like the
connectiontype/data mutation hack in my PCL project. PCL layers are
free to switch between data stores. We don't have a separate data
source object in MapServer, the concept is parameterized by multiple
attributes of layerObj. I am no longer opposed to layer mutation as
practiced by Paul, Howard, and others.
I prefer solution #2. How about calling the method "connect()" and use
the same parameters. We're doing more than just changing the
connectiontype, we are connecting the layer to a backend.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
